Requirements
- nodejs 22 (or later)
- js-controller 6.0.11 (or later)
- Admin Adapter 7.6.20 (or later)
- Awtrix 3 device with firmware 0.98 (or later) - e.g. Ulanzi TC001
Buy here: Aliexpress.com, here: Amazon.de or here: ulanzi.de (Affiliate-Links)
Getting started
- Flash the firmware on your device and add it to your WiFi network - see documentation
- Install the awtrix-light adapter in ioBroker (and add a new instance)
- Open the instance configuration and enter the IP address of the device in your local network
FAQ
Can I use the adapter to disable the native apps (like battery state and sensor data)?
No, this feature has been removed in the awtrix light firmware. Please use the on screen menu to hide these apps.
Is it possible to replace boolean values with other text (not true/false)?
Just create an alias in alias.0 of type string and convert your boolean value into any other text with a read function (like val ? 'open' : 'closed'). This is an ioBroker feature and not related to this adapter.
How can I update to the latest firmware version?
Just use the onscreen menu and navigate to update. No need to use the web flasher again.
The device is getting hot while charging.
The hardware design is not the best. Please use a power supply which deliveres max. 1A.
Is it possible to remove the battery from the device?
Yes, but you have to open the case with a heat gun (since the front glued to the case) and modify the PCB with a step down converter.
Is it possible to re-order apps?
By default, apps are displayed in the same order as in the instance configuration. Just move an app up or down to change it's position. History apps are always positioned after all custom apps!
To set custom positions for each app, the expert option custom positions has to be enabled. After that, it is possible to define a position on each app.
Can I define a custom number format?
All states (of common.type number) are formatted as configured in the system settings of ioBroker. It is possible to override the system format (since adapter version 0.7.1) by using an expert option. Numbers can be formatted in the following styles:
- System default
xx.xxx,xxxx,xxx.xx(US-Format)xxxxx,xxxxxxx.xx(US-Format)
Is it possible to protect web ui of the device?
Yes, since firware version 0.82 it is possible to configure a user name and a password to protect the access. Since adapter version 0.8.0 it is also possible to enter these credentials in the instance configuration.
How does the hold option in notifications work?
When sending a notification with hold: true, the text will stay on the display until the notification will be confirmed. This can either happen with a press on the middle button of the device, or by setting the state notification.dismiss to true.
Some state changes are not displayed immediately.
If your states changes very often (like every second), some changes will be ignored to prevent frequent requests to the device. Each app has a global "block time" which is configurable in the instance configuration. The default block time is 3 seconds. It is not recommended to set a lower value than 3.
Same apps on multiple devices
If you have multiple awtrix-light devices, it is required to create a new instance for each device. But it is possible to copy all app settings of another instance if you want to display the same information on all devices. Just select the other instance in the app configuration tab.
Example:
- Configure all apps in instance
awtrix-light.0 - Create a new instance for the second device (
awtrix-light.1) - Choose
awtrix-light.0in the instance configuration ofawtrix-light.1to use the same apps on the second device
Since version 0.15.0 (and later) the visibility of custom apps and contents of expert apps are also applied to other devices (when app settings are copied). In the example above the apps of awtrix-light.1 will be hidden automatically if the visibility state of an app in instance awtrix-light.0 changes.
Blockly and JavaScript
sendTo / message box can be used to
- send one time notifications (with text, sound, icon, ...)
- play a custom sound
Notifications
Send a "one time" notification to your device:
sendTo('awtrix-light.0', 'notification', { text: 'haus-automatisierung.com', repeat: 1, stack: true, wakeup: true, hold: false }, (res) => {
if (res && res.error) {
console.error(res.error);
The message object supports all available options of the firmware. See documentation for details.
You can also use a Blockly block to send a notification (doesn't provide all available options).
Sounds
The sound files must be saved as RTTTL fomat in the folder MELODIES. The file extension of these files is .txt. When playing those files, the file extension must not be provided.
To play a (previously created) sound file example.txt:
sendTo('awtrix-light.0', 'sound', { sound: 'example' }, (res) => {
You can also use a Blockly block to play a sound.
To play a custom ringtone:
sendTo('awtrix-light.0', 'rtttl', 'Beep: d=32,o=7,b=120: a,P,c#', (res) => {
Apps
App names must be lowercase (a-z) and unique. No numbers, no capital letters, no special characters, no whitespaces.
The following names are used by internal apps and cannot be used: Time, Date, Temperature, Humidity, Battery.
- You can use the state
activateof each app to bring that app to front - This state has the role
buttonand allows just the valuetrue(other values will raise a warning)
Each custom and history app has a state apps.<name>.visible. If this state is set to false, the app will be removed from the device and no further updates are pushed. This is useful, if a certain app should only be displayed during day time or in a given time range.
Custom apps
%sis a placeholder for the state value%uis a placeholder for the unit of the state object (e.g.°C)
It is possible to define a custom text with those placeholders (e.g. Outside: %s %u).
Custom apps just display acknowledged values! Control states with ack: false are ignored (to prevent duplicate requests and to ensure that values are valid / confirmed)!
The selected state should have the data type string or number. Other tyes (like boolean) are also supported but raise a warning. It is recommended to use an alias state with a convert function to replace a boolean value with text (e.g. val ? 'on' : 'off' or val ? 'open' : 'closed'). See ioBroker documentation for details. This standard feature is not related to this adapter.
The following combinations will lead to a warning in the log:
- A custom app with a selected object id of a state, but
%sis missing in the text - A custom app with a selected object id of a state without a unit
common.unit, but%uis used in the text - A custom app without a selected object, but
%shas been used in the text
History apps / graphs
TODO
History apps just display acknowledged history values! Control states with ack: false are filtered and ignored!
Expert apps
Expert apps are available since apdater version 0.10.0. They allow to set all values manually and to implement your own logic by controlling all data via states. To create a new expert app
- Go to expert options in instance settings
- Create a new expert app by choosing a name (e.g.
test) - Save and close the instance settings
After that, all controllable states for the app name test will be created in awtrix-light.0.apps.test. Just set values of icon, text and other states by using your own scripts and logic (e.g. JavaScript or Blockly).
Example: Weather App
Base Object
Requires adapter version 2.0.0 (or newer)
The base object is a basic defition of an awtrix app to allow all possible attributes. The base object will be extended with other attributes of the expert app.
Example: If you want to use the rainbow effect, but there is no state to set this feature directly, you can define this in the base object (as JSON): { "rainbow": true }.
See documentation for available attributes.
Hide native apps
If you want to disable/hide a native app (like battery, temperature or humidity): Use the on screen menu on the device! See documentation for details.
4.0.0 (2026-07-30)
- (@Brainbug01) Added option/setting for global overlay
- (@klein0r) admin 7.6.20 and js-controller 6.0.11 (or later) are required
- (@klein0r) Acknowledge new values of buttons (for admin ui)
- (@klein0r) Fixed state object role definitions
3.0.0 (2025-10-21)
- (@klein0r) admin 7.6.17 and js-controller 6.0.11 (or later) are required
2.0.0 (2025-05-02)
- (@klein0r) Added base object for expert apps to allow all options
- (@klein0r) Added responsive design for admin config
1.7.0 (2025-04-08)
- (@klein0r) Improved error handling when adapter is not ready (starting)
- (@klein0r) Added scroll speed to expert apps
- (@klein0r) Added icons for custom apps in object tree
1.6.0 (2025-01-27)
Updated recommended firmware version to 0.98
- (@klein0r) Updated dependencies
Copyright (c) 2026 Matthias Kleine info@haus-automatisierung.com
