Anthbot Genie
Unofficial cloud adapter for Anthbot Genie robotic lawn mowers with telemetry, diagnostics, consumables, zones, and controls
Current Release
0.1.13
reloxx13
Unofficial ioBroker adapter for Anthbot Genie robotic lawn mowers, focused on detailed Genie telemetry, diagnostics, and mower control across Genie 600/1000/3000/5000 and the newer M5/M9 models.
The adapter connects to the Anthbot cloud account, discovers bound mowers, reads cloud and IoT shadow data, and exposes a broad state tree for status, settings, mower commands, zone data, consumables, location, diagnostics, and raw troubleshooting payloads in ioBroker.
It is intended for users who want more than a basic online/battery/status view: RTK and base station state, firmware and OTA details, network and SIM information, GPS and pose data, map lifecycle timestamps, mower error details, consumable lifetimes, rain settings, zone metadata, and writable mowing controls are exposed as ioBroker states.
This adapter is available in the ioBroker latest repository. Please report feedback and test results in the ioBroker forum thread.
An example ioBroker Blockly with conditions for mower automation is available in the Blockly automation example.
Features
  • Anthbot cloud login with encrypted password storage in ioBroker native config
  • Automatic discovery of mowers bound to the configured Anthbot account
  • Region and IoT endpoint lookup per mower
  • Automatic refresh of temporary IoT credentials after AWS IoT 403 responses
  • Polling of property and service shadows
  • Detailed status states for connection, online state, battery, mower status, charging state, mowing time, mowing area, total mowing time/area, map status, mapping task state, errors, active mowing mode, point mowing, and zone counts
  • Diagnostic states for RTK fix, RTK base station, moved antenna warnings, firmware versions, OTA progress, WiFi, cellular, SIM, Bluetooth, camera/map flags, obstacle avoidance, security flags, system timestamps, and cloud-backed mower error data
  • Location states for anti-loss GPS coordinates and local mower pose
  • Consumable lifetime states and reset buttons for charging port, cameras, and blades
  • Writable control states for full-map mowing, zone mowing, cutting height, voice volume, custom mowing direction, obstacle avoidance, rain settings, and mowing near the charging pile
  • Command states for full mowing, stop, return to dock, pause return to dock, grass dump, disk maintenance mode, edge mowing, mowing near the charging pile, point mowing, refresh, manual zone mowing, and automatic zone mowing
  • Manual and automatic zone metadata as JSON states, including active manual zone IDs
  • Read-only PNG map image states for the native map, RTK mowed-area mask, and historical mowing path
  • Raw property shadow, service shadow, Anthbot event-code translations, and area definition payloads for troubleshooting and automation debugging
Requirements
  • ioBroker with js-controller >= 6.0.11
  • ioBroker admin >= 7.6.20
  • Node.js >= 22
  • Anthbot account with at least one bound Genie mower
  • Internet access from the ioBroker host to the Anthbot cloud and AWS IoT endpoint
Installation
The adapter is available in the ioBroker latest repository and can be installed from the ioBroker adapter view or from the CLI.
ioBroker Admin
If the latest repository is not active yet, open ioBroker Admin, go to Settings -> Repositories, select or enable latest, and refresh the adapter list.
Then open the adapter view, search for anthbot-genie, and install the adapter from the latest repository.
CLI
Install with:
iobroker repo set latest
iobroker update
iobroker add anthbot-genie
or explicitly with a version:
iobroker add anthbot-genie@0.1.13
Supported devices
  • Genie 600
  • Genie 1000
  • Genie 3000
  • Genie 5000
  • M5
  • M9
Other Anthbot models may still work when they expose the same cloud and shadow payload structure, but they are not explicitly mapped or documented here yet.
Development
  • npm install installs runtime and development dependencies.
  • npm run lint checks code style using ESLint.
  • npm run lint:fix applies automatically fixable ESLint changes.
  • npm run check runs TypeScript and Node.js syntax checks for the adapter entrypoint, split library modules, and test files.
  • npm run test:js runs unit tests.
  • npm run test:package runs package validation tests.
  • npm run test:integration runs integration tests.
  • npm run test runs check, unit tests, and package validation.
  • npm run check:repo runs the ioBroker repository checker.
  • npm run translate runs the ioBroker adapter-dev translation workflow.
  • npm run release creates a new ioBroker package release.
Translations
  • Admin/JSON Config translations live in admin/i18n/<lang>.json.
  • Backend/runtime object-name translations live in i18n/<lang>.json.
  • After adding or removing translatable strings, update the English source files and run npm run translate so future Weblate and adapter-dev syncs stay aligned.
Configuration
Open the adapter instance configuration in ioBroker Admin and set:
SettingDescriptionDefault
Anthbot account usernameUsername or email address of the Anthbot accountempty
Anthbot account passwordAnthbot account password, stored encrypted by ioBrokerempty
Area codePhone or account area code, for example 49 for Germany49
API hostAnthbot cloud API hostapi.anthbot.com
Poll interval in secondsPolling interval for mower data. The adapter enforces at least 10 seconds.60
Fetch map (high CPU usage)Download and render the native map, RTK mask, and historical mowing pathfalse
Generate map with paths (even higher CPU usage)Download and render the historical mowing path in the map image. Requires map fetching.false
Error description languageLanguage used for Anthbot cloud error descriptionsEnglish
When either map option is disabled, the adapter stops requesting or rendering that map data and leaves existing map state values unchanged.
After saving the configuration, start or restart the adapter instance.
States
The adapter creates one device tree per mower serial number. If Anthbot ever returns a serial with characters that are unsafe for ioBroker object IDs, the adapter normalizes only those characters while keeping the original serial number in the device object's native metadata:
anthbot-genie.<instance>.<serial>.*
Info
StateTypeDescription
info.connectionbooleanGlobal adapter cloud connection state
<serial>.info.aliasstringMower alias from Anthbot
<serial>.info.modelstringMower model/category
<serial>.info.regionstringAnthbot/AWS IoT region
<serial>.info.endpointstringIoT endpoint used for shadow access
<serial>.info.onlinebooleanOnline state reported by the mower
<serial>.info.chargingbooleanWhether the mower is currently charging
<serial>.info.lastServiceCommandstringLast reported service command
<serial>.info.lastPollstringISO timestamp of the last successful poll
Metrics
StateTypeUnitDescription
<serial>.metrics.batteryLevelnumber%Battery level
<serial>.metrics.status.mowerstringNormalized mower status
<serial>.metrics.status.robotRawstringRaw robot status
<serial>.metrics.status.modeRawstringRaw mode.value status reported by M5/M9 models
<serial>.metrics.mowing.timenumbersReported mowing time
<serial>.metrics.mowing.areanumberm2Reported mowing area
<serial>.metrics.mowing.totalTimenumbersTotal mowing time reported by M5/M9 models
<serial>.metrics.mowing.totalAreanumberm2Total mowing area reported by M5/M9 models
<serial>.metrics.mowing.borderActivebooleanBorder mowing active
<serial>.metrics.mowing.nearChargerActivebooleanNear-charger mowing active
<serial>.metrics.mowing.fullYardActivebooleanFull-yard mowing active
<serial>.metrics.pointMowing.activebooleanPoint mowing active
<serial>.metrics.pointMowing.xnumberLast point mowing X coordinate
<serial>.metrics.pointMowing.ynumberLast point mowing Y coordinate
<serial>.metrics.zones.manualCountnumberNumber of manual zones
<serial>.metrics.zones.autoCountnumberNumber of automatic zones
<serial>.metrics.map.totalAreanumberm2Total mapped area
<serial>.metrics.map.statusstringRaw map status
<serial>.metrics.map.mappingTaskStatestringMapping task state reported by M5/M9 models
<serial>.metrics.error.codenumberLast mower error code
<serial>.metrics.error.descriptionstringHuman-readable error description from the cached Anthbot event-code list when known
<serial>.metrics.error.activebooleanWhether a non-zero mower error is active
The adapter keeps the same state tree for all supported mower models. On models that do not expose the M5/M9-specific payload fields, the states metrics.status.modeRaw, metrics.mowing.totalTime, metrics.mowing.totalArea, and metrics.map.mappingTaskState are still created but remain empty or null.
Map images
<serial>.map.imagestringNative navigation map as a PNG data URI
<serial>.map.imageWithRtkMaskstringNative navigation map with Anthbot's rtk_mask_map as a PNG data URI
<serial>.map.imageWithMowedPathstringNative navigation map with the downloaded historical mowing path as a PNG data URI
<serial>.map.mowedPathstringJSON array with the exact historical path points used for map.imageWithMowedPath
The three image states are read-only and use the media.image role. The map.mowedPath state is read-only and uses the json role. The adapter downloads Anthbot's multi_maps map file, extracts maps/remote_map_navi.map, and renders the native raster with the app-compatible light palette. map.image contains only the map; map.imageWithRtkMask adds the complete maps/rtk_mask_map mowed-area raster; map.imageWithMowedPath requests req_history_mapping_path, downloads path_<SN>.txt, renders the historical path in blue, and adds the current mower pose as a yellow robot icon plus the native charger marker below it. map.mowedPath contains the same JSON path points used by that PNG. Its x and y values use the native historical-path centimetre coordinates; divide them by 100 to convert them to the local map metres used by the pose states. The bundled app assets are oriented with the mower front pointing down and are rotated using location.pose.yaw - 90° (for example, a live yaw of about -16° points the front right); the generated fallback uses the same orientation. The charger marker and the read-only location.charger.x/location.charger.y states are read from charger_point in maps/remote_map.json; the state coordinates are exposed in metres. Both overlay images render configured forbidden zones in red. The historical image never falls back to the short live curpath. The images and path state are refreshed when the native map identity, timestamp, history path, mower pose, or charger point changes. Missing or invalid map data leaves the states empty while the adapter continues polling.
The two map settings deliberately control different work:
  • fetchMap = false: no map archive, raster, PNG, or history path is requested. Existing values of the map and charger coordinate states remain unchanged, so a previously generated map and charger position can still be displayed, but they are not updated.
  • fetchMap = true and generateMapWithPaths = false: the native map and RTK-mask states are updated. The historical path is not requested, and map.imageWithMowedPath and map.mowedPath remain unchanged. Use map.image or map.imageWithRtkMask for the lower-CPU map view.
  • Both settings true: all three image states and the map.mowedPath state are generated; map.imageWithMowedPath contains the historical path and the current robot icon.
VIS: map with the integrated robot icon
Use this direct path when both map settings are enabled. Bind the VIS image widget to <serial>.map.imageWithMowedPath; the adapter already draws the historical path and the robot icon at the current pose. No second VIS icon widget is needed. Keep the image container at the PNG's native aspect ratio (404:488).
VIS: map with a separate overlay icon
Use this lower-CPU path when fetchMap = true and generateMapWithPaths = false. Bind the image widget to <serial>.map.image or <serial>.map.imageWithRtkMask, then place a transparent icon widget absolutely above it. Bind or calculate its position from <serial>.location.pose.x and <serial>.location.pose.y. These states are metres; the map metadata supplies the origin and resolution. Keep both widgets in the same relatively positioned container and use the same aspect ratio (404:488), otherwise object-fit: contain can introduce letterboxing and offset the overlay icon. If fetchMap = false, the map image may still show an old state, but neither the map nor its separate overlay position is refreshed by the adapter.
After the pose-state meter conversion is deployed, location.pose.x and location.pose.y are metres. Convert them to map pixels with the map header values from maps/remote_map.json:
const map = {
    width: 404,
    height: 488,
    resolution: 0.05,
    xMin: -15.353175,
    yMin: -9.549684,
const pixelX = (poseX - map.xMin) / map.resolution;
const pixelY = map.height - 1 - (poseY - map.yMin) / map.resolution;
const poseYaw = Number(poseYawState); // <serial>.location.pose.yaw
icon.style.left = `${(pixelX / map.width) * 100}%`;
icon.style.top = `${(pixelY / map.height) * 100}%`;
icon.style.transform = `translate(-50%, -50%) rotate(${poseYaw - 90}deg)`;
For the current snapshot, pose.x = 0.094 and pose.y = 0.356 place the icon at approximately pixel (309, 289), or left: 76.5% and top: 59.2%. Define poseYaw from <serial>.location.pose.yaw; with a front-down icon, apply poseYaw - 90 so a live yaw around -16 points the front to the right. The adapter does not currently publish map width, height, resolution, or origin as states, so these values must be refreshed when the mower creates a new map; do not mix map-array pixels with the mower's metre coordinates.
Yaw: origin and calculation
<serial>.location.pose.yaw is the mower heading reported by Anthbot as pose.yaw. It is expressed in degrees and is not converted from millimetres. The adapter converts only pose.x and pose.y from millimetres to metres; yaw is passed through unchanged. X/Y describe the mower's position, so yaw must not be calculated from the current position alone.
For a separate VIS icon whose source image has the mower front pointing down, calculate the image rotation with a fixed 90° offset:
const yawDeg = Number(yawState); // <serial>.location.pose.yaw
const iconRotationDeg = yawDeg - 90;
icon.style.transform = `translate(-50%, -50%) rotate(${iconRotationDeg}deg)`;
The -90° offset aligns Anthbot's heading convention with the front-down asset. The same formula is used for the integrated map icon and its generated fallback. Examples: yaw = 90° results in image rotation (front down), while the live value yaw = -16° results in -106° (equivalent to 254°) and points the front to the right. If yaw is unavailable, keep the asset in its default front-down orientation.
Robot icon source
The inspected Anthbot app bundle contains local map-marker resources, including the Genie pic_device_map asset, model-specific S2/S3/M9Pro variants, and the view_map_battery_position charger marker. These are packaged UI files selected by the app; the cloud/API payload and downloaded map archive do not provide a reusable icon URL or icon state. The adapter packages the matching app-derived marker assets for known models and uses its own self-contained robot marker if an asset is missing, unreadable, or the model is unknown. The adapter does not depend on the app being installed.
Location
<serial>.location.gps.latitudenumberGPS latitude from anti-loss position data
<serial>.location.gps.longitudenumberGPS longitude from anti-loss position data
<serial>.location.pose.xnumberLocal mower pose X in metres
<serial>.location.pose.ynumberLocal mower pose Y in metres
<serial>.location.pose.yawnumberLocal mower pose yaw
<serial>.location.pose.typestringReported pose type
<serial>.location.charger.xnumberCharger X coordinate in metres from the native map metadata
<serial>.location.charger.ynumberCharger Y coordinate in metres from the native map metadata
Diagnostics
The diagnostics channel exposes read-only troubleshooting data derived from the mower shadow, including RTK state, RTK base state, camera/map/network flags, obstacle avoidance, firmware versions, OTA progress, WiFi/SIM details, timestamps, and the next appointment. On M5/M9 models, the adapter also maps net_config.*, mode.value, error.value, map.map_area, mapping_task.state, mowing_time.value, and mowing_area.value into the existing ioBroker state tree where the meanings match.
Consumables
<serial>.consumable.chargingPort.lifenumber%Charging port lifetime
<serial>.consumable.chargingPort.resetbooleanReset charging port lifetime
<serial>.consumable.cameras.lifenumber%Cameras lifetime
<serial>.consumable.cameras.resetbooleanReset cameras lifetime
<serial>.consumable.blades.lifenumber%Blades lifetime
<serial>.consumable.blades.resetbooleanReset blades lifetime
The mower accepts consumable reset commands only when the related lifetime value is at or below 5%.
Controls
Writable control states update mower settings through the Anthbot IoT service shadow. The adapter handles the model-specific shadow payload encoding internally, so the same ioBroker control states can be used across supported mower models.
StateTypeRangeDescription
<serial>.controls.fullMapMowing.mowHeightnumber30..70 mm, 5 mm stepsSet full-map cutting height
<serial>.controls.fullMapMowing.includeEdgeTrimmingbooleantrue/falseInclude edge trimming in full-map mowing
<serial>.controls.fullMapMowing.customMowingDirectionnumber0..180 degSet full-map custom mowing direction
<serial>.controls.fullMapMowing.customMowingDirectionEnabledbooleantrue/falseEnable or disable full-map custom mowing direction
<serial>.controls.zoneMowing.mowHeightnumber30..70 mm, 5 mm stepsSet zone mowing cutting height
<serial>.controls.zoneMowing.mowCountnumber1..3Set zone mowing passes
<serial>.controls.zoneMowing.customMowingDirectionnumber0..180 degSet zone mowing direction
<serial>.controls.zoneMowing.customMowingDirectionEnabledbooleantrue/falseEnable or disable zone mowing direction
<serial>.controls.zoneMowing.obstacleAvoidanceEnabledbooleantrue/falseEnable or disable zone obstacle avoidance
<serial>.controls.zoneMowing.obstacleAvoidanceLevelnumber0..2Set zone obstacle avoidance level
<serial>.controls.voiceVolumenumber0..100 %Set voice volume
<serial>.controls.rain.perceptionEnabledbooleantrue/falseEnable or disable rain perception
<serial>.controls.rain.continueTimeHoursnumber0..8 hSet rain continue time in hours
<serial>.controls.nearChargerMowing.enabledbooleantrue/falseEnable or disable mowing near the charging pile
<serial>.controls.nearChargerMowing.mowHeightnumber30..70 mm, 5 mm stepsSet cutting height for mowing near the charging pile
<serial>.controls.nearChargerMowing.mowCountnumber1..3Set mowing passes near the charging pile
<serial>.controls.nearChargerMowing.obstacleAvoidanceEnabledbooleantrue/falseEnable or disable obstacle avoidance near the charging pile
<serial>.controls.nearChargerMowing.obstacleAvoidanceLevelnumber0..2Set obstacle avoidance level near the charging pile
Commands
Command states are writable. Button states are reset to false after execution. Zone command states are reset to an empty string after execution. Consumable reset buttons are exposed under consumable.
<serial>.commands.device.findbooleanFind the robot
<serial>.commands.device.refreshbooleanRequest all mower properties and refresh states
<serial>.commands.device.cancelRtkAntennaMovedbooleanCancel the RTK antenna moved warning
<serial>.commands.docking.startReturnbooleanReturn to the charging dock
<serial>.commands.docking.pauseReturnbooleanPause return to the charging dock
<serial>.commands.maintenance.startGrassDumpbooleanStart grass dump
<serial>.commands.maintenance.startDiskMaintenancebooleanStart disk maintenance mode
<serial>.commands.mowing.startFullMapbooleanStart full-map mowing
<serial>.commands.mowing.startZonestringStart mowing one or more manual zones
<serial>.commands.mowing.startAutoZonestringStart mowing one or more automatic zones
<serial>.commands.mowing.startPointstringStart point mowing with x,y or {"x":123,"y":456}
<serial>.commands.mowing.startEdgebooleanStart edge mowing
<serial>.commands.mowing.startNearChargerbooleanStart mowing near the charging pile
<serial>.commands.mowing.pausebooleanPause mowing
<serial>.commands.mowing.resumebooleanResume mowing
<serial>.commands.mowing.stopbooleanStop all mower tasks
<serial>.commands.mowing.endbooleanEnd mowing
<serial>.commands.mowing.stopPointbooleanStop point mowing
Availability of commands.maintenance.startDiskMaintenance, commands.maintenance.startGrassDump, commands.mowing.startEdge, commands.mowing.startNearCharger, and commands.mowing.startPoint may depend on mower model, firmware, current mower mode, and map/edge data.
Zones
<serial>.zones.manual.listJSON stringKnown manual/custom zones
<serial>.zones.manual.activeIdsJSON stringCurrently active manual zone IDs
<serial>.zones.autoListJSON stringKnown automatic/region zones
Raw data
<serial>.raw.shadow.propertyJSON stringRaw property shadow payload
<serial>.raw.shadow.serviceJSON stringRaw service shadow payload
<serial>.raw.shadow.event-codeJSON stringCached Anthbot event-code translation payload used for error descriptions
<serial>.raw.areaDefinitionJSON stringRaw area definition payload
Zone Mowing
The adapter exposes the mower's manual/custom zones in:
<instance>.<serial>.zones.manual.list
This state contains a JSON array with known zones. Use the id or the exact name from that list to start mowing.
Write the selection to:
<instance>.<serial>.commands.mowing.startZone
Accepted values:
  • one zone by ID: 3
  • one zone by name: Front yard
  • multiple zones as comma-separated IDs or names: 3,5,Back yard
  • multiple zones as a JSON array: [3,5,"Back yard"]
After a valid write, the adapter sends custom_area_mow_start with the matched manual zone IDs and clears commands.mowing.startZone again.
Automatic zones work similarly through:
<instance>.<serial>.zones.autoList
<instance>.<serial>.commands.mowing.startAutoZone
For automatic zones, the adapter resolves the selected zone IDs or names to the zone coordinates and sends region_mow_start.
Troubleshooting
Adapter does not connect
  • Check username, password, and area code.
  • Confirm that the mower is visible in the Anthbot app with the same account.
  • Increase the adapter log level to debug and restart the instance.
  • Check anthbot-genie.<instance>.info.connection.
No mower objects are created
  • The Anthbot account must have at least one bound mower.
  • Check the adapter log for No Anthbot devices found for this account.
  • Verify that the ioBroker host has internet access.
Commands do not work
  • Check whether status polling works first.
  • Verify that the target state is under the correct mower serial number.
  • For zone commands, compare the written value with the IDs and names in zones.manual.list or zones.autoList.
  • The adapter automatically refreshes temporary IoT credentials once after an AWS IoT 403; if commands still fail after that retry, check the adapter log for model-specific payload or mower-state errors.
  • Check raw.shadow.service and the adapter log for command errors.
  • Add separate read-only PNG map image states for the native map, RTK mowed-area mask, and downloaded historical mowing path.
  • Add an opt-in Admin checkbox for map downloads and rendering because map generation can use significant CPU.
  • Add a second opt-in Admin checkbox for historical path rendering because it uses additional CPU and cloud requests.
  • Expose local mower pose X/Y states in metres for direct map positioning.
  • Expose charger point X/Y states in metres from the native map metadata.
  • Expose the historical mowing path used by the PNG as a JSON state.
  • Rotate the integrated robot map icon according to the mower pose yaw.
  • Render the native charger marker from the map metadata below the mower icon.
0.1.13 (2026-06-08)
  • Add M5/M9 payload parity for status, battery, error, network, RTK, map, and total mowing metrics while keeping the existing ioBroker state tree stable.
  • Refresh temporary IoT credentials once on AWS IoT 403 responses and retry the failed shadow read or command publish automatically.
  • Refactor the large adapter sources into focused CommonJS modules for Anthbot cloud/shadow clients, payload helpers, adapter object definitions, state derivation, and command handling without changing state IDs or command payload behavior.
  • Expand npm run check so syntax validation covers the split lib/anthbot, lib/adapter, and unit test files through the dedicated syntax-check helper.
0.1.12 (2026-06-06)
  • (reloxx13) FIXED: Create the global info channel and correct the mower status role so the adapter object structure passes ioBroker review checks.
0.1.11 (2026-06-06)
  • Refresh existing mower device/channel/state objects with extendObjectAsync so updated runtime i18n names are applied to already-created objects, not only new ones.
0.1.10 (2026-06-06)
  • Align ioBroker object metadata with the repository object-structure checker by creating the global info channel, correcting the mower status role, and emitting full recommended i18n keys for object names.
  • Keep admin translations in the repository-checker-friendly admin/i18n/<lang>.json layout and load backend/runtime object-name translations from root i18n/<lang>.json files via adapter-core I18n.
0.1.9 (2026-06-06)
  • Drop the temporary --legacy-peer-deps GitHub Actions install override now that the lockfile supports plain npm ci again.
  • Re-enable ESLint in the GitHub Actions quick-check job and align the local lint config with the checked JavaScript codebase.
  • Clean up repository metadata so local repochecker no longer reports actionable findings.
Credits
Special credit to the community Anthbot Genie projects, which made the Anthbot cloud flow and command mapping much easier to understand:
Special thanks to @Riza-Aslan for the M5/M9 support research and payload-mapping work that informed this adapter update.
This ioBroker adapter is an independent project, but it builds on public API research and implementation ideas from that community work.
Legal Notice
This project is unofficial and is not affiliated with, endorsed by, sponsored by, or approved by Anthbot.
Anthbot and Genie names, marks, and logos belong to their respective owners. See NOTICE.md for details.
Older changelog entries are archived in CHANGELOG_OLD.md.
Copyright (c) 2026 reloxx13
See LICENSE for details.
