Overview
The ioBroker AI Assistant Adapter runs a smart assistant in your ioBroker system. The assistant can be used to interact with your ioBroker system, set time-based instructions, trigger-based instructions, and call custom functions. The assistant can be configured with different language models from various providers (e.g., OpenAI, Anthropic, Perplexity, OpenRouter) or custom/self-hosted models. The assistant can be used to automate tasks, control your smart home, or provide information.
Features
- Personalize the name and personality of your assistant
- List, Read and Write ioBroker states
- Set timeouts and cronjobs to run time-based instructions
- Set triggers on ioBroker states with conditions that run instructions when the conditions are met
- Define custom functions with your own data and logic
- Use the admin tab to chat with your personal assistant
Supported Providers
- Anthropic: anthropic.com
- OpenAI: openai.com
- Perplexity: perplexity.ai
- OpenRouter: openrouter.ai
- Deepseek: deepseek.com
- Custom/Self-hosted Models (e.g., LM Studio, LocalAI)
Quick Start
- Install the adapter.
- Set up a provider (e.g., OpenAI, Anthropic, Perplexity, OpenRouter) and get an API Token.
- Configure the adapter with the API Token.
- Select the model you want to use for the assistant.
- Add some ioBroker states under the
Objectstab that will be available to the assistant. - Start communicating with your assistant by sending text requests to the assistant's
text_requeststate and receive responses from thetext_responsestate or use the custom admin tab labeled "Assistant".
Tested Models
The following models have been tested with the adapter and are known to work well:
- Claude 3.5 Sonnet (Anthropic)
- gpt-4o-mini (OpenAI)
- meta-llama/llama-3.3-70b-instruct (OpenRouter)
- deepseek/deepseek-chat (OpenRouter)
- x-ai/grok-beta (OpenRouter)
- perplexity/llama-3.1-sonar-huge-128k-online (Perplexity)
- perplexity/llama-3.1-sonar-large-128k-online (Perplexity)
Configuration
Assistant
Setup your assistant with the following settings:
| Setting | Description |
| Name | The name of your assistant. |
| Model | Select the LLM model that your assistant should use (configured under providers). |
| Personality | Describe the personality of your assistant. |
| Language | Select the language your assistant should use (Currently only English/German supported) |
| Debug / CoT Output | When active the internal thoughts and processes the assistant uses are written to the text_response state. |
| Message History | Include prior messages (for chatbot-like behavior). Set to 0 for single-use tools to minimize token usage. |
| Temperature | Controls response creativity/consistency. |
| Max. Tokens | Limits the response token count. |
| Retry Delay | Delay between retry attempts if the request fails |
| Maximum Retries | Maximum number of retries per request. |
Objects
WARNING: Be careful with the states you give the assistant access to, as it can read and write to all states it has access to.
Setup the ioBrokers objects and states the assistant should have access to.
NOTE: When importing or adding objects please make sure to only add datapoints with the type "state" that can be directly controlled or contains a value to be read!
| Import from Enum.Rooms | Imports all your states from the enum.rooms sorting in ioBroker. (Overwrites all previously set objects!) |
| Sort | All objects with the same sort field will be presented to the assistant in a group (e.g. a room) |
| Name | Use a descriptive name so the assistant understands the function of the objects |
| Object | The ID of the ioBroker state |
Functions
Setup custom functions that should be available to the assistant.
Your custom functions have to write the response to the state you defined in the State (Response) field after the State (Request) is written.
The result can be in any format you like (e.g. JSON, plain text), just make sure the assistant can understand it.
Tipp: You can use the AI-Toolbox Adapter to integrate your assistant with custom AI tools.
NOTE: If you don't write a response to the State (Response) field in 60 Seconds, the function call will fail!
| Name | Use a descriptive name for the custom function |
| Description | Describe what your function does so the assistant understands when to call it |
| State (Request) | This state will be written with a string by the assistant when the function is called |
| State (Response) | This state will be read by the assistant to get the response of the function |
LLM Providers
Configure each AI provider individually:
Anthropic
| API Token | Enter your Anthropic API token. |
| Models | Specify the models to use. |
OpenAI
| API Token | Enter your OpenAI API token. |
Perplexity
| API Token | Enter your Perplexity API token. |
OpenRouter
| API Token | Enter your OpenRouter API token. |
Custom
| Inference Server URL | URL of the custom/self-hosted inference server. |
| API Token for Inference Server | API token for your inference server. |
| Note | Ensure compliance with common AI LLM API standards (e.g., LM Studio API). |
Usage
Simple Conversation
You can interact with your assistant by sending text requests to the text_request state and receiving responses from the text_response state.
Function Calling
The assistant can call all available functions. It does this by determining the function to call based on the text request. If you have Debug/CoT Output enabled, you can see the internal process of the assistant in the text_response state.
State Interaction
The assistant can list, read and write multiple ioBroker states at once. You can use the Objects tab to define which states the assistant should have access to.
Time-based Instructions
The assistant can set timeouts for relative time instructions and cronjobs for specific times. Cronjobs will be listed in the assistant objects tree unter Cronjobs.
Timeouts will only be temporary and will be removed after the timeout is executed or the adapter is restarted.
When a timeout or cronjob is triggered, the assistant will be woken up and the instruction will be executed.
Trigger-based Instructions
The assistant can set triggers on ioBroker states with optional conditions that run instructions when the conditions are met. Triggers will be listed in the assistant objects tree unter Triggers.
When triggered the assistant will be woken up and the instruction will be executed.
Custom Functions
The assistant can call custom functions you defined in the Functions tab. The assistant will write the request to the State (Request) field and expects the response in the State (Response) field.
Function Chaining
The assistant can be used to chain multiple functions together. For example you could setup a cronjob that when executed starts a check of ioBroker states and then calls a custom function with the results.
Clearing Chat History
Sometimes it can be useful to reset your chat history. You can do this by requesting the assistant to clear its history. This will remove all previous messages from the assistant's memory. (e.g. Clear history or Forget the previous messages)
Additional Information
Statistics
Statistics are logged for your assistant and can be viewed in the Statistics object tree.
| Datapoint | Description |
| .statistics.lastRequest | Timestamp of the last request. |
| .statistics.requestCount | Number of sent requests to the assistant |
| .statistics.messages* | JSON array of message history (if message history > 0). |
| .statistics.clear_messages* | Clear message history button. |
| .statistics.tokens_input | Total input tokens used. |
| .statistics.tokens_output | Total output tokens used. |
Development
This adapter is still in development and may contain bugs. Please report any issues you encounter.
Debugging
Set the log level to debug in the ioBroker admin interface for detailed logs.
0.1.4 (2025-06-05)
- (@ToGe3688) Added tab to interact with the assitant in the admin adapter
- (@ToGe3688) Added a custom timeout parameter
- (@GermanBluefox) Corrected using of the states with the multi-language names
0.1.3 (2025-29-01)
- (@ToGe3688) Added support for Deepseek as api provider
- (@ToGe3688) Better display of providers in model selection for admin config
- (@ToGe3688) Fixed object hirarchy
- (@ToGe3688) Fixed state roles
- (@ToGe3688) Fixed onStateChange handler
0.1.2 (2025-12-01)
- (@ToGe3688) Better error handling for Provider APIs
- (@ToGe3688) Anthropic API Versioning
0.1.1 (2025-12-01)
0.1.0 (2025-04-01)
- (@ToGe3688) Beta Release
0.0.3 (2024-31-12)
- (@ToGe3688) Improved handling of malformed model responses
- (@ToGe3688) Fixed a bug where the names of the states were not provided to the assistant
0.0.2 (2024-30-12)
- (@ToGe3688) Fixed Bug in OpenAI Provider
0.0.1 (2024-30-12)
- (@ToGe3688) initial release
The MIT License (MIT)
Copyright (c) 2024-2025 ToGe3688 toge3688@gmail.com
