justGage Widgets
justGage Widgets für ioBroker.vis
Aktueller Release
2.1.7
Entwickler
Pmant, iobroker-community-adapters
Version:
Tests:
justGage Widget für ioBroker.
Screenshot
Zeigeroptionen
Es besteht die Möglichkeit, die Zeigeroptionen zu definieren:
  "toplength": null,
  "bottomlength": null,
  "bottomwidth": null,
  "stroke": "none",
  "stroke_width": 0,
  "stroke_linecap": "square",
  "color": "#000000"
Es muss sich um ein gültiges JSON-Objekt handeln. Einzelne Kontingente sind nicht zulässig! Weitere Informationen zu Zeigeroptionen finden Sie hier: https://github.com/toorshia/justgage#pointer-options
2.1.7 (2024-03-07)
  • (bluefox) Added message by installation or update if vis is not installed
2.1.6 (2024-03-04)
  • (bluefox) Added the possibility to invert the value by gauge
  • (bluefox) do not load scripts if the widget is not used
2.1.5 (2024-03-03)
  • (bluefox) fixed the problem in vis-2
2.1.0 (2023-12-10)
  • (mcm1957) 'Title' has been read
  • (mcm1957) Code base has been restored to release 1.0.2 which has not been saved to GitHub
2.0.2 (2023-11-25)
  • (mcm1957) Mode setting has been adapted
  • (mcm1957) Adapter-core dependency has been removed
2.0.1 (2023-11-24)
  • (mcm1957) Missing files blocking any functionality have been added to package again
2.0.0 (2023-10-24)
  • (mcm1957) Adapter has been moved to iobroker-community-adapters organization
1.0.1 (2019-10-07)
  • (bluefox) fixed min max
0.7.1 (2016-12-14)
  • (Pmant) changed max brightness to max brightness of initial color
0.7.0 (2016-12-14)
  • (jens-maus) added value formatting
  • (jens-maus) added value multiplier
0.6.1 (2016-11-25)
  • (bluefox) Updated justgage.js
0.6.0 (2016-07-31)
  • (Pmant) added no-gradient-option to Justgage widget
  • (Pmant) added a full brightness option to Justgage widget
  • (jens-maus) added missing unit fields
0.5.1 (2016-07-21)
  • (jens-maus) fixed auto fill max, min, unit
0.5.0 (2016-07-01)
  • (Pmant) fixed default indicator
  • (Pmant) added option to change background-color instead of text-color
  • (Pmant) added option to always set full brightness colors
0.4.2 (2016-06-05)
  • (PArns) fixed mid default value if max != 100 & min != 0
0.4.1 (2016-03-20)
  • (bluefox) removed config
0.4.0 (2016-02-19)
  • (Pmant) replaced pow with sliders
  • (bluefox) fixed resize
0.3.0 (2016-02-16)
  • (bluefox) fixed error with two gauges at creation
  • (bluefox) fixed small errors
  • (bluefox) added new widget: value & indication
  • (bluefox) filled automatically max, min, unit
0.2.5 (2016-02-13)
  • (Pmant) fixed indicator
  • (bluefox) added russian translations
0.2.2 (2016-02-12)
  • (Pmant) possible donut fix
0.2.0 (2016-02-11)
  • (Pmant) added indicator widget
0.1.1 (2016-02-10)
  • (Pmant) initial checkin
The MIT License (MIT)
Copyright (c) 2023-2026 iobroker-community-adapters Copyright (c) 2015-2019 Pmant patrickmo@gmx.de
