этот адаптер содержит только виджеты vis-2 для адаптера rssfeed.
Подробное описание виджетов и функционала смотрите в разделе Адаптер RSS-канала.
1.2.0 (2025-06-05)
- switch build framework from CRA to vite
- Remove deprecated RSSMarquee widget. RSSMarquee5 is already available
1.1.2 (2025-03-20)
- add a missing build file
1.1.1 (2025-03-20)
- fix marqueeV5 widget
- fix build process
1.0.0 (2025-02-19)
- remove common.noConfig from io-package.json
- add popup as opening type for marquee widget
0.3.6 (2024-09-18)
- remove 0.3.4 from io-package.json
0.3.5 (2024-08-09)
- improve link styling in the marquee widget
- fix key and group handling
- fix issues from an adapter checker
0.3.3 (2024-07-25)
- fix widgeturl from debug to productive
0.3.2 (2024-07-25)
- introduce innerhtml component that is capable to execute raw javascript and improve links for the marquee widget
- fix translation
0.3.1 (2024-07-24)
- fix widget access url
0.3.0 (2024-07-24)
- intoroduction of the rss multi feed widget
- update icons for light and dark theme
- improved translation
0.2.4 (2024-06-25)
- fix github commands to non deprecated
0.2.3 (2024-06-25)
- switch nodeversion in github actions
- change upload to v4
- upgrade github commands to non deprecated
- adjust copy commands in gulpfile
0.2.2 (2024-06-25)
- remove withstyles
- translate some missing keys
0.2.1 (2024-06-24)
- set node to 20 in deploy task
0.2.0 (2024-06-24)
- fine tuning
0.1.3 (2024-06-22)
- add ace build files to gulp
0.1.2 (2024-06-22)
- move library to ace/ejs lib to dependency
0.1.1 (2024-06-22)
- reverte timepout in tests
0.1.0 (2024-06-22)
- Erstes Testrelease
The MIT License (MIT)
Copyright (c) 2025 oweitman oweitman@gmx.de
