Vis 2 Widgetsammlung
Vis 2 Widgetsammlung für ioBroker
Aktueller Release
2.6.0
Entwickler
Steiger04
Lizenz
Widgets für ioBroker.vis 2.0
📖 Ausführliche Dokumentation im GitHub Wiki
Widgets
Zustand
Schaltflächengruppe
Schieberegler
Eingabe
Schalten
Kontrollkästchen
Dialog
Wählen
RadioGroup
Messgerät
Licht
JsonTable
2.6.0 (2026-07-24)
  • (steiger04) Input widget added (text/number input with inline editing)
  • (steiger04) noIcon option now correctly hides the widget icon
2.5.1 (2026-07-20)
  • (steiger04) JSON Table: image column type — render URLs, data-URIs and icon glyphs as avatar cells (auto-detected, XSS-safe)
2.5.0 (2026-07-17)
  • (steiger04) Theme wizard with presets, live preview, custom fonts and widget sizing
  • (steiger04) Slider marker defaults and label styling fixed
  • (steiger04) Gauge min/max fallback fixed
  • (steiger04) JSON Table quick filtering fixed
2.4.2 (2026-07-06)
  • (steiger04) JSON Table: bug fixes and improvements (date handling, table state persistence, refactor)
  • (steiger04) ColorPickerField: debouncing for picker drag events and refactor
  • (steiger04) CheckboxCollection: refactor (helpers, memoization, type safety)
2.4.1 (2026-03-11)
  • (steiger04) Add HTML rendering support for table cells of Json Table
  • (steiger04) Bug fixing
2.4.0 (2026-03-01)
  • (steiger04) JSON Table added
2.3.3 (2026-02-16)
  • (steiger04) ignoreCommonStates attribute added. Please read attribut tooltip (i)
2.3.2 (2026-02-14)
  • (steiger04) Long press for ButtonGroupCollection widget fixed
2.3.1 (2026-02-13)
  • (steiger04) ButtonGroupCollection widget bug fixing
2.3.0 (2026-02-12)
  • (steiger04) Widget optimizations
  • (steiger04) User documentation fixed (GitHub Wiki)
2.2.1 (2026-01-18)
  • (steiger04) Slider widget color for min / max icon optimized
2.2.0 (2026-01-18)
  • (steiger04) CollectionWidgets optimized and expanded
2.1.1 (2026-01-09)
  • (steiger04) GradientColorPicker bug fixed
2.1.0 (2026-01-09)
  • (steiger04) Slider widget optimized
  • (steiger04) RadioButtonGroup widget optimized
  • (steiger04) RadioGroup widget optimized
2.0.11 (2025-12-24)
  • (steiger04) sync-wiki.yml for en and de optimized
2.0.10 (2025-12-24)
  • (steiger04) sync-wiki.yml optimized
2.0.9 (2025-12-24)
  • (steiger04) sync-wiki.yml changed
2.0.8 (2025-12-24)
  • (steiger04) User documentation added (GitHub Wiki)
2.0.7 (2025-12-24)
  • (steiger04) Gauge widget optimized
2.0.6 (2025-12-23)
  • (steiger04) gitignore changed
2.0.5 (2025-12-23)
2.0.4 (2025-12-23)
2.0.3 (2025-12-23)
  • (steiger04) test-and-release.yml changed
2.0.2 (2025-12-23)
  • (steiger04) package.json changed
2.0.1 (2025-12-23)
2.0.0 (2025-12-23)
  • (steiger04) Switch to vite and typescript
  • (steiger04) Widget optimizations and bug fixes
1.8.1 (2025-06-30)
  • (steiger04) Dialog feature (automate open and close via state) added
  • (steiger04) Up handler for mouse up in State added
1.8.0 (2025-05-30)
  • (steiger04) Light added
1.7.9 (2025-04-04)
1.7.8 (2025-04-04)
  • (steiger04) Push button functionality for State widget added
1.7.7 (2025-03-31)
  • (steiger04) Slider optimized
1.7.6 (2025-03-31)
  • (steiger04) Dialog with width and height in pixel
1.7.5 (2025-03-23)
  • (steiger04) Dialog bug fixed
1.7.4 (2025-03-22)
  • (steiger04) Header as title for Dialog
  • (steiger04) Gauge bug fixed
1.7.3 (2025-03-21)
1.7.2 (2025-03-21)
  • (steiger04) Gauge optimized
1.7.1 (2025-03-21)
1.7.0 (2025-03-19)
  • (steiger04) Gauge added
1.6.1 (2025-03-15)
  • (steiger04) Radio group optimizations
1.6.0 (2025-03-13)
  • (steiger04) Radio group added
1.5.2 (2025-03-05)
1.5.1 (2025-03-03)
  • (steiger04) Select bug fixed
1.5.0 (2025-03-02)
  • (steiger04) Select added
1.4.0 (2025-02-27)
  • (steiger04) Dialog added
1.3.0 (2025-02-20)
  • (steiger04) Button functionality for State and Button group
1.2.0 (2025-02-16)
  • (steiger04) Checkbox added and widget optimizations
1.1.19 (2025-02-08)
  • (steiger04) Button group optimized
1.1.18 (2025-02-08)
  • (steiger04) State optimized
1.1.17 (2025-02-05)
  • (steiger04) bugfixing header / footer
1.1.16 (2025-02-05)
  • (steiger04) only valid oid's allowed
1.1.15 (2025-02-05)
  • (steiger04) bugfixing Slider
1.1.14 (2025-02-04)
1.1.13 (2025-02-03)
  • (steiger04) delay via throttle and debounce optimized
1.1.12 (2025-02-02)
  • (steiger04) Active group for slider added
1.1.11 (2025-02-01)
  • (steiger04) HTML-Text optimizations
1.1.10 (2025-01-30)
  • (steiger04) HTML-Text for header, value and footer
1.1.9 (2025-01-28)
  • (steiger04) bugfixing style bindings
1.1.8 (2025-01-28)
  • (steiger04) bugfixing data bindings
1.1.7 (2025-01-28)
  • (steiger04) Switch optimized
1.1.6 (2025-01-26)
1.1.0 (2025-01-25)
  • (steiger04) Switch widget added
1.0.3 (2025-01-20)
  • (steiger04) initial commit
The MIT License (MIT)
Copyright (c) 2026 Steiger04 steiger04@posteo.de
