Javascript
Global functions
You can define the global scripts in the “global” folder. All global scripts are available on all instances. If global script is disabled, it will not be used. Global script will be just prepend to the normal script and compiled, so you cannot share data between scripts via global scrips. Use states for it.
Best practice:
Create two instances of javascript adapter: one “test” and one “production”. After the script is tested in the “test” instance, it can be moved to “production”. By that you can restart the “test” instance as you want.
Following functions can be used in scripts:
require – load some module
Following modules are pre-loaded: fs, crypto, wake_on_lan, request, suncalc, util, path, os, net, events, dns.
To use other modules go to iobroker/adapter/javascript folder and run in console npm install . After npm successfully finished it can be used in script engine.
Buffer
Buffer – Node.js Buffer, read here http://nodejs.org/api/buffer.html
log – Gives out the message into log
Message is a string and sev is one of the following: ‘debug’, ‘info’, ‘warn’, ‘error’. Default severity is ‘info’
exec – execute some OS command, like “cp file1 file2”
Execute system command and get the outputs.
on – Subscribe on changes or updates of some state
The callback function will return the object as parameter with following content:
Note: early was newState instead of state. It is still working.
Example:
You can use following parameters to specify the trigger:
parameter type/value description
logic string “and” or “or” logic to combine the conditions (default: “and”)
id string name ist equal to given one
RegExp name matched to regular expression
name string name ist equal to given one
change string “eq”, “ne”, “gt”, “ge”, “lt”, “le”, “any”
“eq” (equal) New value must be equal to old one (state.val == oldState.val)
“ne” (not equal) New value must be not equal to the old one (state.val != oldState.val) If pattern is id-string this value is used by default
“gt” (greater) New value must be greater than old value (state.val > oldState.val)
“ge” (greater or equal) New value must be greater or equal to old one (state.val >= oldState.val)
“lt” (smaller) New value must be smaller than old one (state.val < oldState.val)
“le” (smaller or equal) New value must be smaller or equal to old value (state.val <= oldState.val)
“any” Trigger will be raised if just the new value comes
val mixed New value must be equal to given one
valNe mixed New value must be not equal to given one
valGt mixed New value must be greater than given one
valGe mixed New value must be greater or equal to given one
valLt mixed New value must be smaller than given one
valLe mixed New value must be smaller or equal to given one
ack boolean Acknowledged state of new value is equal to given one
oldVal mixed Previous value must be equal to given one
oldValNe mixed Previous value must be not equal to given one
oldValGt mixed Previous value must be greater than given one
oldValGe mixed Previous value must be greater or equal to given one
oldValLt mixed Previous value must be smaller than given one
oldValLe mixed Previous value must be smaller or equal to given one
oldAck bool Acknowledged state of previous value is equal to given one
ts string New value time stamp must be equal to given one (state.ts == ts)
tsGt string New value time stamp must be not equal to the given one (state.ts != ts)
tsGe string New value time stamp must be greater than given value (state.ts > ts)
tsLt string New value time stamp must be greater or equal to given one (state.ts >= ts)
tsLe string New value time stamp must be smaller than given one (state.ts < ts)
oldTs string Previous time stamp must be equal to given one (oldState.ts == ts)
oldTsGt string Previous time stamp must be not equal to the given one (oldState.ts != ts)
oldTsGe string Previous time stamp must be greater than given value (oldState.ts > ts)
oldTsLt string Previous time stamp must be greater or equal to given one (oldState.ts >= ts)
oldTsLe string Previous time stamp must be smaller than given one (oldState.ts < ts)
lc string Last change time stamp must be equal to given one (state.lc == lc)
lcGt string Last change time stamp must be not equal to the given one (state.lc != lc)
lcGe string Last change time stamp must be greater than given value (state.lc > lc)
lcLt string Last change time stamp must be greater or equal to given one (state.lc >= lc)
lcLe string Last change time stamp must be smaller than given one (state.lc < lc)
oldLc string Previous last change time stamp must be equal to given one (oldState.lc == lc)
oldLcGt string Previous last change time stamp must be not equal to the given one (oldState.lc != lc)
oldLcGe string Previous last change time stamp must be greater than given value (oldState.lc > lc)
oldLcLt string Previous last change time stamp must be greater or equal to given one (oldState.lc >= lc)
oldLcLe string Previous last change time stamp must be smaller than given one (oldState.lc < lc)
channelId string Channel ID must be equal to given one
RegExp Channel ID matched to regular expression
channelName string Channel name must be equal to given one
RegExp Channel name matched to regular expression
deviceId string Device ID must be equal to given one
RegExp Device ID matched to regular expression
deviceName string Device name must be equal to given one
RegExp Device name matched to regular expression
enumId string State belongs to given enum
RegExp One enum ID of state satisfy the given regular expression
enumName string State belongs to given enum
RegExp One enum name of state satisfy the given regular expression
from string New value is from defined adapter
fromNe string New value is not from defined adapter
oldFrom string Old value is from defined adapter
oldFromNe string Old value is not from defined adapter
Examples: Trigger on all states with ID ‘*.STATE’ if they are acknowledged and have new value “true”.
Note: you can use RegExp directly:
To simply connect two states with each other, write:
All changes of stateId1 will be written to stateId2.
Please note, that by default “change” is equal to “any”, except when only id as string is set (like on("id", function (){});). In last case change will be set to “ne”.
Function “on” returns handler back. This handler can be used by unsubscribe.
subscribe – same as on
unsubscribe
Remove all subscriptions for given object ID or for given handler.
getSubscriptions
Get the list of subscriptions.
Example of result:
schedule
Time scheduler with astro-funktion.
Time schedule
Pattern can be a string with Cron-Syntax, e.G.:
Pattern can be an object, it is used especially if seconds are required:
Pattern can be a Javascript Date object (some specific time point) – in this case only it will be triggered only one time.
Note: the newest version of schedule supports seconds too, so you can specify:
to trigger every second second.
Astro- function
Astro-function can be used via “astro” attribute:
The attribute “shift” is the offset in minutes. It can be negative too, to define time before astro event.
Following values can be used as attribute in astro-function:
  • sunrise: sunrise (top edge of the sun appears on the horizon)
  • sunriseEnd: sunrise ends (bottom edge of the sun touches the horizon)
  • goldenHourEnd: morning golden hour (soft light, best time for photography) ends
  • solarNoon: solar noon (sun is in the highest position)
  • goldenHour: evening golden hour starts
  • sunsetStart: sunset starts (bottom edge of the sun touches the horizon)
  • sunset: sunset (sun disappears below the horizon, evening civil twilight starts)
  • dusk: dusk (evening nautical twilight starts)
  • nauticalDusk: nautical dusk (evening astronomical twilight starts)
  • night: night starts (dark enough for astronomical observations)
  • nightEnd: night ends (morning astronomical twilight starts)
  • nauticalDawn: nautical dawn (morning nautical twilight starts)
  • dawn: dawn (morning nautical twilight ends, morning civil twilight starts)
  • nadir: nadir (darkest moment of the night, sun is in the lowest position)
Note: to use “astro”-function the “latitude” and “longitude” must be defined in javascript adapter settings.
Note: you can use “on” function for schedule with small modification:
clearSchedule
If no “astro” function used you can cancel the schedule later. To allow this the schedule object must be saved:
getAstroDate
Returns a javascript Date object for the specified pattern. For valid pattern values see the Astro section in the schedule function.
The returned Date object is calculated for the passed date. If no date is provided, the current day is used.
isAstroDay
Returns true if the current time is between the astro sunrise and sunset.
compareTime
Compares given time with limits.
If timeToCompare is not given, so the actual time will be used.
Following operations are possible:
  • > – if given time is greater as startTime
  • >= – if given time is greater or equal to startTime
  • < – if given time is less as startTime
  • <= – if given time is less or equal to startTime
  • == – if given time is equal to startTime
  • <> – if given time is not equal to startTime
  • between – if given time is between startTime and endTime
  • not between – if given time is not between startTime and endTime
Time can be Date object or Date with time or just time.
setState
Please refer to https://github.com/ioBroker/ioBroker/wiki/Adapter-Development-Documentation#commands-and-statusesfor usage of “ack”. Short:
  • ack = false : Script wants to send a command to be executed by the target device/adapter
  • ack = true : Command was successfully executed and state is updated as positive result
setStateDelayed
Same as setState but with delay in milliseconds. You can clear all running delay for this ID (by default). E.g.
This function returns handler of the timer and this timer can be individually stopped by clearStateDelayed
clearStateDelayed
Clears all delayed tasks for specified state ID or some specific delayed task.
getState
Returns state of id in form {val: value, ack: true/false, ts: timestamp, lc: lastchanged, from: origin} .
If state does not exist, it will be returned following object: {val: null, notExist: true}
getObject
Get description of object id as stored in system. You can specify the enumeration name. If this is defined, two additional attributes will be added to result: enumIds and enumNames. These arrays has all enumerations, where ID is member of. E.g:
getObject ('adapter.N.objectName', 'rooms')
gives back in enumIds all rooms, where the requested object is a member. You can define “true” as enumName to get back all enumerations.
setObject
Write object into DB. This command can be disabled in adapter’s settings. Use this function carefully, while the global settings can be damaged.
Use it like this:
extendObject
It is almost the same as setObject, but first it reads the object and tries to merge all settings together.
Use it like this:
getIdByName
returns id of the object with given name. If there are more than one object with this name the result will be an array. If alwaysArray flag is set, the result will be always an array if some ID found.
getEnums
Get the list of existing enumerations with members, like:
createState
Create state and object in javascript space if does not exist, e.g. “javascript.0.mystate”.
Parameters:
  • name: name of the state without namespace, e.g. “mystate”
  • initialValue: variable can be initialized after created. Value “undefined” means do not initialize value.
  • forceCreation: create state independent of if state yet exists or not.
  • common: common description of object see description here
  • native: native description of object. Any specific information.
  • callback: called after state is created and initialized.
It is possible short type of createState:
  • createState(‘myVariable’) – simply create variable if does not exist
  • createState(‘myVariable’, 1) – create variable if does not exist and initialize it with value 1
  • createState(‘myVariable’, {name: ‘My own variable’, unit: ‘°C’}, function () {log(‘created’);});
  • createState(‘myVariable’, 1, {name: ‘My own variable’, unit: ‘°C’}) – create variable if does not exist with specific name and units
deleteState
deleteState('myVariable')_ - simply delete variable if exists
sendTo:
setInterval
Same as javascript setInterval.
clearInterval
Same as javascript clearInterval.
setTimeout
Same as javascript setTimeout.
clearTimeout
Same as javascript clearTimeout.
formatDate
Parameters:
  • date: number of milliseconds from state.ts or state.lc (Number milliseconds from 1970.01.01 00:00:00) or javascript new Date() object or number of milliseconds from (new Date().getTime())
  • format: Can be “null”, so the system time format will be used, elsewise
    • YYYY, JJJJ, ГГГГ – full year, e.g 2015
    • YY, JJ, ГГ – short year, e.g 15
    • MM, ММ(cyrillic) – full month, e.g. 01
    • M, М(cyrillic) – short month, e.g. 1
    • DD, TT, ДД – full day, e.g. 02
    • D, T, Д – short day, e.g. 2
    • hh, SS, чч – full hours, e.g. 03
    • h, S, ч – short hours, e.g. 3
    • mm, мм(cyrillic) – full minutes, e.g. 04
    • m, м(cyrillic) – short minutes, e.g. 4
    • ss, сс(cyrillic) – full seconds, e.g. 05
    • s, с(cyrillic) – short seconds, e.g. 5
    • sss, ссс(cyrillic) – milliseconds
    • WW, НН(cyrillic) – full week day as text
    • W, Н(cyrillic) – short week day as text
    • OO, ОО(cyrillic) – full month as text
    • O, О(cyrillic) – short month as text
Example
formatDate(new Date(), “YYYY-MM-DD”) => Date “2015-02-24” formatDate(new Date(), “hh:mm”) => Hours and minutes “17:41” formatDate(state.ts) => “24.02.2015” formatDate(state.ts, “JJJJ.MM.TT SS:mm:ss.sss) => “2015.02.15 17:41:98.123” formatDate(new Date(), “WW”) => Day of week “Tuesday” formatDate(new Date(), “W”) => Day of week “Tu”
getDateObject
Converts string or number to Date object. If only hours are given it will add current date to it and will try to convert.
getDateObject(“20:00”) => “Tue Aug 09 2016 20:00:00 GMT+0200”
formatValue
Formats any value (strings too) to number. Replaces point with comma if configured in system. Decimals specify digits after comma. Default value is 2. Format is optional:
  • ‘.,’: 1234.567 => 1.234,56
  • ‘,.’: 1234.567 => 1,234.56
  • ‘ .’: 1234.567 => 1 234.56
adapterSubscribe
Sends to adapter message “subscribe” to inform adapter. If adapter has common flag “subscribable” in case of function “subscribe” this function will be called automatically.
adapterUnsubscribe
Sends to adapter message “unsubscribe” to inform adapter to not poll the values.
$ – Selector
Format of selector: ”’name[commonAttr=something1](enumName=something2){nativeName=something3}[id=idfilter][state.id=idfilter]”’
name can be: state, channel or device “idfilter” can have wildcards ‘*’
Prefixes (not implemented – should be discussed) : # – take by name and not by id . – filter by role § – filter by room
Example:
  • $(‘state[id=.STATE]’) or $(‘state[state.id=.STATE]’) or $(‘*.STATE’) – select all states where id ends with “.STATE”.
  • $(‘state[id=’hm-rpc.0.]’) or $(‘hm-rpc.0.‘) – returns all states of adapter instance hm-rpc.0
  • $(‘channel(rooms=Living room)’) – all states in room “Living room”
  • $(‘channel{TYPE=BLIND}[state.id=*.LEVEL]’) – Get all shutter of Homematic
  • $(‘channel[role=switch](rooms=Living room)[state.id=*.STATE]’).setState(false) – Switch all states with .STATE of channels with role “switch” in “Living room” to false
  • $(‘channel[state.id=*.STATE](functions=Windows)’).each(function (id, i) {log(id);}); – print all states of enum “windows” in log
  • $(‘.switch §”Living room”) – Take states with all switches in ‘Living room’ (not implemented – should be discussed)
  • $(‘channel .switch §”Living room”) – Take states with all switches in ‘Living room’ (not implemented – should be discussed)
*** Explanation *** Lets take a look at:
This code searches in channels. Find all channels with common.role=”switch” and belongs to enum.rooms.Wohnzimmer. Take all their states, where id ends with “.STATE and make subscription on all these states. If some of these states changes the callback will be called like for “on” function.
Following functions are possible, setValue, getValue (only from first), on, each
You can interrupt the “each” loop by returning the false value, like:
readFile
The result will be given in callback. Read file from DB from folder “javascript”.
writeFile
The optional error code will be given in callback. fileName is the name of file in DB. All files are stored in folder “javascript”. if you want to write to other folders, e.g. to “/vis.0/” use setFile for that.
The file that looks like ‘/subfolder/file.txt’ will be stored under “/javascript/subfolder/file.txt” and can be accessed over web server with http://ip:8082/javascript/subfolder/file.txt
delFile
Delete file or directory. fileName is the name of file or directory in DB.
This function is alias for unlink.
onStop
Install callback, that will be called if script stopped. Used e.g. to stop communication or to close connections.
timeout is default 1000ms.
getHistory
Read history from specified instance. if no instance specified the system default history instance will be taken.
Possible options you can find here.
Additionally to these parameters you must specify “id” and you may specify timeout (default: 20000ms).
One more example:
*Note: * of course history must be first enabled for selected ID in admin.
runScript
Starts or stops other scripts (and itself too) by name. There is a second parameter
startScript
Same as
stopScript
Same as runScript('scriptName', false);
If stopScript is called without arguments, it will stop itself:
isScriptActive
Returns if script enabled or disabled. Please note, that that does not give back if the script now running or not. Script can be finished, but still activated.
name
It is not a function. It is a variable with script name, that is visible in script’s scope.
instance
It is not a function. It is a variable with javascript instance, that is visible in script’s scope.
Option – “Do not subscribe all states on start”
There are two modes of subscribe on states:
  • Adapter subscribes on all changes at start and receives all changes of all states (it is easy to use getStates(id), but required more CPU and RAM):
  • Adapter subscribes every time on specified ID if “on/subscribe” called. In this mode the adapter receives only updates for desired states. It is very perform and RAM efficiency, but you cannot access states directly in getState. You must use callback to get the result of state:
It is because the adapter does not have the value of state in RAM and must ask central DB for the value.
Scripts activity
There is a possibility to enabled and disable scripts via states. For every script the state will be created with name javascript.INSTANCE.scriptEnabled.SCRIPT_NAME. Scripts can be activated and deactivated by controlling of this state with ack=false.
Note
If in the script some modules or functions are used with callbacks or cyclic calls, except setTimeout/setInterval, so they will be called again and again even if the new version of script exists or script is deleted. For example the following script:
was deleted by user before callback returns. The callback will be executed anyway. To fix this feature restart the javascript adapter.
You can use “cb” function to wrap you callback, like this
to be sure, that no callback will be called if script is deleted or modified.
