How to install node.js on linux
Sometimes the node.js version does not suit to the required one or there is no any node.js at all.
First of all we should find the type of processor. There possible types of CPUs:
  • armv6l
  • armv7l
  • arm64
  • ppc64
  • ppc64le
  • x64
  • x86
For all these CPU types there is a precompiled binary package.
To find the type of CPU write
cat /proc/cpuinfo
You will get something like this (example for ODROID):
Here from “model name” we can guess, that it is armv7l.
Now we must find the binary for that. The binary has following name:
https://nodejs.org/dist/v[VERSION]/node-v[VERSION]-linux-[CPU-TYPE].tar.xz
Actually the latest LTS(Long time support) 4 version is 4.6.0.
We can check it here: https://nodejs.org/dist/
So the link, what we need is https://nodejs.org/dist/v4.6.0/node-v4.6.0-linux-armv7l.tar.xz.
And now the installation process. Normally there is no need to uninstall old node.js package, but you can do it:
apt-get --purge remove node
apt-get --purge remove nodejs
apt-get autoremove
reboot
And the installation is:
cd /tmp
wget https://nodejs.org/dist/v4.6.0/node-v4.6.0-linux-armv7l.tar.xz -O node.tar.xz
cd /usr/local
sudo tar --strip-components=1 -xvf /tmp/node.tar.xz
Please notice to use your download link in wget command.
After installation of node.js the command “node -v” should show the node.js version. if not, create alias to bin file:
sudo ln -s /usr/local/bin/nodejs /usr/bin/node
