Raspberry (JESSIE) – fast install
Attention! Do not use this guide if a final image from the download section of this page has been used. Our images from the download area are completely finished – including the installed ioBroker. A new installation according to this guide is not necessary (and has already led to problems).
You will find here the installation instructions for ioBroker on Raspberry PI with Image Jessie
If you cannot get it run, please post your Problem in forum.
Required Hardware
  • Raspberry PI
  • Power supply (it is important to have a good one. You will have stability problems with weak or bad quality power supplies)
  • SD Card
Required / important Links
Installation instructions
Installation of Raspbian
  2. Write Image to he SD Card (Win32Diskimager)
  3. Start RaspberryPi
  4. Connect to Raspberry via Putty. Login: pi, Password: raspberry
  5. Configure RaspberryPi with sudo raspi-config
  6. Enable Root Access
    1. sudo nano /etc/ssh/sshd_config
    2. Edit file: Change PermitRootLogin without-password in PermitRootLogin yes and save
    3. Start SSH anew: sudo /etc/init.d/ssh restart
    4. sudo su (now is Root Mode active)
    5. Change default password with passwd
  7. Logout and login as root via Putty
Installation of Node.js
  1. Kernel Update: sudo apt-get update && sudo apt-get upgrade
  2. Deinstall old node.je Version (not required by Jessie Light)
    1. apt-get --purge remove node
    2. apt-get --purge remove nodejs
    3. apt-get autoremove
    4. reboot
  3. login as root via Putty
  4. Install Node.js anew for Raspbery 2/3
    1. curl -sL https://deb.nodesource.com/setup_6.x | sudo -E bash -
    2. sudo apt-get install -y build-essential python-rpi.gpio python nodejs
    3. reboot
  5. Install Node.js anew for Raspbery 1
    1. wget http://node-arm.herokuapp.com/node_archive_armhf.deb
    2. sudo dpkg -i node_archive_armhf.deb
    3. sudo apt-get install build-essential python python-rpi.gpio
    4. reboot
  6. login as root via Putty
  7. After installation of node.js the command “node -v” should show the node.js version. if not, create alias to bin file::
    sudo ln -s /usr/local/bin/nodejs /usr/bin/node
Installation of ioBroker
  1. install ioBroker
    1. sudo mkdir /opt/iobroker
    2. sudo chmod 777 /opt/iobroker
    3. cd /opt/iobroker
    4. sudo npm install iobroker --unsafe-perm
  2. ioBroker über IP im Webbrowser aufrufen: http://IP-Adresse:8081
Set static IP address (optional)
sudo nano /etc/dhcpcd.conf
Call per interface (example):
interface eth0
static ip_address=
static routers=
static domain_name_servers=
