Scripts and logic
Adapter text2command
  Description Adapter text2command  (Text to command) is used for analyzing of received textual information and command implementation according to a defined in advance a set of rules. Installation and configuration of this adapter doesn't req...
Javascript
Global functions You can define the global scripts in the "global" folder. All global scripts are available on all instances. If global script is disabled, it will not be used. Global script will be just prepend to the normal script and compiled,...
