Adapter text2command
Fork me on GitHub
  Description
Adapter text2command (Text to command) is used for analyzing of received textual information and command implementation according to a defined in advance a set of rules. Installation and configuration of this adapter doesn’t require other adapters in a system, however, it is used together with other adapters, which pass text expressions, e.g.: telegram or applications for Android- iobroker.vis. Also, in addition to command implementation, it allows to give different answers in text, and it is also possible to use for sayit adapter, for example, (confirmation of  command or a simple answer to a question).
 Information
Actual version
 Necessary  terms
 Key words
 administration, commands, rules
Github icon_link Link
 Platform
Javascript/Node.js
  Installation
Installation is performed in a tab Adapters on the page system administration.  In a adapter’s group Scripts & logics  find a line Text to command and press the plus button in the line to the right.
On the screen you’ll see a pop-up window of an adapter installation. After the work is done it closes itself automatically.
If everything goes well, on the tab Adapter configuration you’ll see the line text2command.0 with installed adapter version.
As a default adapter is not running, but to start it, press inactive button. Press to start (red one with an icon play).
Now we can go to edit the rule’s page. To do this, we press the button Open the application (there on the tab Adapter settings in the line of installed adapter version) or in administration we add the tab text->commands.o
 Setting Up
Main Window description
As it was mentioned above, the Main Window of setting adapter rules can become accesible if we click the appropriate
button on the tab Adapter settings in the line of set sample adapters or by adding the tab with tab editing button.
From top left-right:
buttons of rule edtiting- creating, saving the changes, updating the list and ID change;
Field Filter can filter the list of rules by a key word;
Field Text Phrase and the buttons clear field, send the text phrase into a adapter-is useful when the driver is tuned up, one can add the text phrase(for example “what time is it now”) press the button send into a driver-supervising the work (answer is in a popup message);
Choosing the Language(choice from the list)-the main language which makes possible the command exchange and giving the answers;
Settting up the answer in ID-if in the rule formatting there’s a confirmation text, it will be passed in a variable
text2command..response and into the variable, shown in the field(if it’s taken)- we can pass to sayit, for example, for a voice confirmation command or in responde to a question.
When the driver starts working(entry text appears), the program checks the matching of all the rules from top to bottom. It should be considered, if the tick Interupt is not installed, several rules can start working, the ones with a higher priority are put into the top of the list. If the tick Interupt is installed on the first working rule, so the driver won’t be checking the rules.
 Key words task syntax of approval.
Key words task syntax can include regular expression, for example /^light\son|^lamp\son/. We should take into account that it is a register responsive.
Key words work this way:
  • Key words are separated by a space bar
  • all key words must be present in a sentence to activate this rule. For example, key words: turn on the light activate the rule, if in the entry there will be text please turn on the light or turn on the light in the flat and don’t activate the rule if in the entry there will be the text turn on everything or turn on the light.
  • Each key word has many forms of sounding, key words variations must be separated by “/” symbol. For example, key words:turn on/switch on/give the lights/the light use the rule, if in the entry there will be switch on / turn on the lights please or give me lights.
  •  Key word may have many variations(cases, plural number, verb/participle, conversational…), all should be counted as variants. For example, window/windows/small window/small  windows/ air vent/vent/air
Key word
  • Key word variations can b described in diffrent languages, for example, key phrase temperature/temp in the room/ bedroom uses the rule, if in the entry there will be voice commands what temperature is it in the room? Or a command via the driver telegram /temp_bedroom.
Text for confirmation may contain the specific phrase or a phrase variation, which are seperated by the symbol “/”
(the variant is randomly chosen). For example, text of rule confirmation what’s your name can be shown in a view: My name is Kate/Ratusha/Catherine my name / My name is Ekaterina.
In a confirmation text it is possible to use auto replace while working with certain rules(for a example a temperature request). We use the following syntax:
  • %s-inclusion of variable values( variable ID in indicated in a rule parameter),
  • %u-inclusion of unit of measure of a variable
  • %n-inclusion of the name of the variable
  Using functions and categories
To use the rule Switch on/Switch off the devices or lift up/down the shutters(look below) one needs to set up categories of functions and rooms.  . Categories of groups and the categories themselves are created and tuned up
in the tab Categories in the page of system administration.
The following functions can be used:
Light
  • deminuating (controling the level of lightning)
  • discrete control(switch on/off)
 Backlighting
  • deminuating(control of the level of backlighting)
 Shutters/windows
  • analogue controling(level of opening)
  • discrete control(open/close)
 Curtains
  • analogue control (level of opening)
  • discrete control (open/close)
 Heating/warning up
  • analogue control (temperature),
  • discrete control (switch on/off)
 Music
  • play
  • stop/pause
Security
  • put on/off the security
 Lock
  • close
  • open
the following rooms can be used:
  • the living room
  • dining room
  • bedroom
  • bathroom
  • children’s room
  • guest toilet
  • toilet
  • corridor/hall
  • kitchen
  • terrace/balcony
  • dining-room
  • garage
  • stairs
  • garden
  • back yard
  • guest room
  • pantry
  • roof
  • anteroom
  • washing room
  • boiler room
  • hanger
  • warm house
Rule description
To add a new rule, one should choose from the list the main functions of  entry.
Rule What time is it
This is a simple rule. the result of which is a display of text with the current system time, no parameters are given, the approval text is not configured. The text can be input into a driver sayit(configure the answer in ID), we can use in the script for more difficult answer or with the dialogue elements. The key phrase by default what is it can be enlarged by adding the elements of a conversational language, for example:
Rule what is your name
This rule is a bit more complex than the one before,because the answer mask can be tuned up, the result will be the text output about system personalisation(electronic helper name).It’s possible to output the text into sayit (configure the answer in ID), one can use in a script for more complex answer or with dialogue elements. The key
phrase by default what is your name can be enlarged by adding the elements of a convesational language, there maybe several variants of answer, separated by the  character ‘/’, for example
he rule what is a street temperature.
The work result of this rule will be the  text output with a current street temperature.One more setting appears- the Parameter, where we choose the necessary value, in which the current temperature of air outside the building is stored, i.e. the street temperature. This can be a data from a local weather station(according to MQTT/ModBUS) or set up weather service, for example of driver weatherunderground forecast(as given a screenshot example), yr.no or the others. Key words together with a output syntax can be set up to one’s liking, but for the direct output of temperature values auto-replacement is used- characters %s replaces variable values(rounded to an integer), but %u – unit of measurement (in this case centigrates). For example:
What temperature is inside the house
Practically analogous to the rule above, the only difference that we use the inside temperature(house, flat, office…)
The initial value can contain a variable of  weather sensors inside the bulding or seperate sensors inside the room or different sensors, for example, of a heating system
Rules of switching on/ off the equipment and lift up/down the shutters.
In order to use these rules, one should tune up the categories, to be precise  enum.rooms – rooms, where the rule enum.functions-what to control(window, heating, light etc).This applies to the tab Categories of pages of system administration and can look like this:
In each category(room and function) we can attach the following values. For example, the variable mqtt.0.arduinomega51.relay_light1 (a controller based on board ) arduino с ethernet-shield is switched on to MQTT, a light relay №1)  controls the light in the room, according to this variable one can compare the room-hall, function-light. This can be done in the tab Categories or Objects- to find the variable and fill in the necessary fields, choosing the values from the list.
Shown as the example of a variable playing of a driver sayit.
Discrete control:the examples of a key phrase turn on the light in the living room or open the kitchen window.
If  there is a tick on Answer confirm, the answer will be switched on/off %function% in %room%. Where a %function%-this is a performed function, and %room%– a room where the rule worked.
Analogous control:examples of key phrase switch on the light at 50 % or open the kitchen shutters in the kitchen at 80%.
If the tick is on Answer confirm, then the reply will be switch on the light at 50% or open the shutters in the kitchen at 80%.
If the tick is on Confirm answer, the answer will be open %function% in %room% on …%. Where %function%- is performed function, but %room%- a room where the rule worked.
 Rule record the text into a variable
This rule allows with a key phrase to send the textual information into a system variable. Let’s look at the example
The husband is busy in the garage, a wife is cooking dinner. We have the tuned up driver sayit.1(different from sayit.o, where the confirmation text is output, which gives the sound in the garage at the device SONOS. The wife is saying a keyphrase Call his husband from the garage  ) and then the text Andrew, the dinner is ready! (look at the text phrase on a screenshot). The tune up is the following:
  • First parameter-choosing the variable, where the text will be sent
  • Second parameter -a mask to send, in the given case it is just the text itself, symbols %s
  • The text of approval- to approve the little text will be pronounced the sent text
  • Answer in ID- is passed to the driver sayit.0, which is tuned for outputting a sound in the house/flat/kitchen (in order to hear the answer)
  • Another example. In the driver javascript.o is written a script for different modes(security, worry,night, nobody,guests, cinema etc), according to which other scripts are used and when changing the mode, there will be initialisatuib of certain values. We can control the regimes with our voice(through android app iobroker.vis) and through the robot telegram. In that case the room settings will be the following:
  The rule switch smth on/off
This is a simple rule in tuning and usage, which allows to record a certain value into a certain variable. For example, if the system has an integrated ‘smart kettle’, we can make it turn itself on. In the example, the kettle is manipulated with the controller Arduino with ethernet shield by the protocol MQTT, the variable is called  mqtt.0.arduinomini53.relay_pot. To switch on the kettle you should set the variable to true, when it boils the contoller will automatically change it to false.
The rule ask about something
This rule allows to give the value (supports autoset up and variants of answers through the character”/”) of certain variable, for example the text-weather forecast or a numerical value-the temperature, humidity and etc.
The above mentioned example of switching on of a smart kettle, suppose, that it is smart, that it passes to the system the temperature value and the amount of water in the kettle. So before switching on one has to make sure if it is hot and whether there is water. To know the temperature (variable mqtt.0.arduinomini53.temp_water) , the rule will look like this:
One should remember when the rule is activated, the variable must contain all the necessary information.
The rule well-done/Thank you
Very simple in use and tuning up the rules. Used specially for keeping the dialogue up(Just for fun). The answers can be replaced with your own-it depends on your imagination.
  Working with sample adapters.
After the intallation into a system, the driver creates two variables in the system:
  • text-to this variable the text phrase will be passed to sort out by the rules
  • response-in this variable there will be an answer/confirmation, if it is introduced by the rule.The analogy of written text in the variable text is sending the text phrase from driver configuration( it is realised for the comfort of testing of work of the rules). If we indicate in parameters answer in ID-chose the variable (to activate the driver sayit), so the answer will be put into response, and into a given variable(for example one needs to pass an answer to a script for further analisis and this answer needs to be pronounced for a confirmation).It is possible to pass the answer into a script for further sorting and the same answer should be pronounced to confirm. One can send text commands from javascript, and through function to receive the answer to confirm, for example:sendTo('text2command', 'switch on the kitchen light', function (err, response) {
  console.log('Response is: ' + response);
 Examples
As it has been mentioned above, the driver text2comand is used in a bunch with other driver and the app iobroker.vis
The examples of work with the adapter telegram can be seen on the page of description of this driver.
